please help error ubuntu 20.04.
Postby nszerver » Sun Nov 17, 2024 11:02 am
Hello, thank you very much for accepting me, but I would like to ask for a little help.
And I have the following products:
* 2 TBS6991SE cards
* 1 TBS 6905 card
error log:
root@ryzen:/home/ryzen# journalctl -p err -b -1
-- Logs begin at Tue 2024-06-25 07:07:14 CEST, end at Sun 2024-11-17 03:51:16 CET. --
Nov 16 17:18:53 ryzen kernel: WARNING: You are using an experimental version of the media stack.
As the driver is backported to an older kernel, it doesn't offer
enough quality for its usage in production.
Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
Nov 16 17:18:53 ryzen kernel: kfd kfd: amdgpu: error getting iommu info. is the iommu enabled?
Nov 16 17:18:53 ryzen kernel: kfd kfd: amdgpu: Error initializing iommuv2
Nov 16 17:18:53 ryzen kernel: kfd kfd: amdgpu: device 1002:15dd NOT added due to errors
Nov 16 17:18:53 ryzen blkmapd[463]: open pipe file /run/rpc_pipefs/nfs/blocklayout failed: No such file or directory
Use it with care.
36ce48448be5dd42669a5199f61e85da1a68cf60 media: pci/tbsecp3: Fix irq handler for DMA events.
Nov 16 17:19:01 ryzen kernel: dvb_net: dvb7_0: no feed to stop
Nov 16 17:19:01 ryzen systemd-udevd[510]: dvb7_0: Failed to get link config: No such device
Nov 16 17:19:01 ryzen kernel: dvb_net: dvb6_0: no feed to stop
Nov 16 17:19:01 ryzen systemd-udevd[510]: dvb6_0: Failed to get link config: No such device
Nov 16 17:19:02 ryzen kernel: dvb_net: dvb5_0: no feed to stop
Nov 16 17:19:02 ryzen systemd-udevd[510]: dvb5_0: Failed to get link config: No such device
Nov 16 17:19:02 ryzen kernel: dvb_net: dvb4_0: no feed to stop
Nov 16 17:19:02 ryzen systemd-udevd[510]: dvb4_0: Failed to get link config: No such device
Nov 16 17:19:02 ryzen kernel: dvb_net: dvb3_0: no feed to stop
Nov 16 17:19:02 ryzen systemd-udevd[510]: dvb3_0: Failed to get link config: No such device
Nov 16 17:19:02 ryzen kernel: dvb_net: dvb2_0: no feed to stop
Nov 16 17:19:02 ryzen systemd-udevd[510]: dvb2_0: Failed to get link config: No such device
Nov 16 17:19:03 ryzen kernel: dvb_net: dvb1_0: no feed to stop
Nov 16 17:19:03 ryzen systemd-udevd[510]: dvb1_0: Failed to get link config: No such device
Nov 16 17:19:03 ryzen kernel: dvb_net: dvb0_0: no feed to stop
Nov 16 17:19:03 ryzen systemd-udevd[510]: dvb0_0: Failed to get link config: No such device
Nov 16 17:25:41 ryzen blkmapd[463]: exit on signal(15)
And that would be a problem after 30 minutes, intermittently, and half the broadcast would stop. it only works when I restart the server, again for half an hour
root@ryzen:/home/ryzen# dmesg | grep fron
[ 6.983860] SAA716x Budget 0000:01:00.0: DVB: registering adapter 1 frontend 0 (TurboSight TBS 6991SE DVB-S/S2 )...
[ 6.995007] TBSECP3 driver 0000:06:00.0: DVB: registering adapter 0 frontend 0 (TurboSight TBS 6905 DVB-S/S2 )...
[ 7.114644] TBSECP3 driver 0000:06:00.0: DVB: registering adapter 3 frontend 0 (TurboSight TBS 6905 DVB-S/S2 )...
[ 7.136616] SAA716x Budget 0000:01:00.0: DVB: registering adapter 2 frontend 0 (TurboSight TBS 6991SE DVB-S/S2 )...
[ 7.266072] TBSECP3 driver 0000:06:00.0: DVB: registering adapter 4 frontend 0 (TurboSight TBS 6905 DVB-S/S2 )...
[ 7.312561] SAA716x Budget 0000:05:00.0: DVB: registering adapter 5 frontend 0 (TurboSight TBS 6991SE DVB-S/S2 )...
[ 7.386988] TBSECP3 driver 0000:06:00.0: DVB: registering adapter 6 frontend 0 (TurboSight TBS 6905 DVB-S/S2 )...
[ 7.461056] SAA716x Budget 0000:05:00.0: DVB: registering adapter 7 frontend 0 (TurboSight TBS 6991SE DVB-S/S2 )...
root@ryzen:/home/ryzen# lspci -vvv | grep 6909
pcilib: sysfs_read_vpd: read failed: Input/output error
nszerver
Re: please help error ubuntu 20.04.
Postby smile » Mon Nov 18, 2024 10:51 am
Hello
they are all old product . they were working fine before?
because i suspect they may have some parts that age. which prevents then from working for a long time.
and we already have not those card, so we can not do a test on our side.
Best Regards
smile
Return to Install and setup
