6922SE and motor control
Postby eelstrebor » Wed Dec 02, 2015 2:36 am
I didn't see any specs for how much current draw the 6922SE can handle when starting a DisEQc 2.x motor. My motor is a STAB HH90 and it requires a start up current of 350 mA. I don't know if that's an issue or not. All I know is that the dish movement is erratic - sometimes it moves and sometimes it doesn't.
eelstrebor
Re: 6922SE and motor control
Postby Alfredo » Sat Dec 05, 2015 10:01 am
I have a 6922 with DMS Internationa SG-2100 and anntena of 90cm and work well
Alfredo
Postby eelstrebor » Sat Dec 05, 2015 11:35 am
Are you using Linux or Windows? I'm using Ubuntu linux 14.04 64 bit. Not easy to use with Linux. I don't know if it's any easier on Windows but it appears that there are utilities for Windows that don't seem to be available for linux. Kinda hard to diagnose my problems. Anyway, it seems that my dish movement problem has corrected itself. But, I'm considering going back to a STB. Disappointed.
eelstrebor
Return to General discussion
