[ Moderator Control Panel ]
by savskii » Tue Aug 04, 2015 9:24 pm
Hi, is there anyway to open powervu channels using linux pc and any tbs tuners?
Powervu is working with keys on enigma2 and can be watched if i send udp or http streams from PC using like dvblast to tsreader then using powervuemu with keys to decrypt channels and watch them
I have tryed tsdecypt and cesbo astra but both dont support powervu
thanks
savskii
by matchboxx » Sun Feb 07, 2016 4:41 pm
Wha not?
You need only sat tuner working with matrix and right oscam, it work on arm without problem.
matchboxx
by developer » Mon Nov 14, 2016 11:59 pm
how do we put the powervu key in that case?
developer
Return to General discussion
