playing HD movies
playing HD movies
Postby suspension » Sat Jun 13, 2015 2:07 am
I am trying to play an HD movie with VLC in this board and it is extremely slow. I would like to get some help to understand the issue.
suspension
Re: playing HD movies
Postby steven » Wed Jun 24, 2015 6:13 pm
Hi suspension
Which firmware you are using?For MatrixTV system using XBMC should be ok.
And the VLC you are using maybe have not added hardware acceleration support.
Postby suspension » Fri Jun 26, 2015 1:11 am
Hi Steven
I want VLC specifically.
VLC support gstreamer, and there are a set of gstreamer plugins that use hardware acceleration of imx6Q SOC.
I compiled gstreamer and gstreamer plugin. But it does not work. However VLC correctly loads the gstreamer plugin without errors.
My question is, the gstreamer plugin needs things like firmware-imx, imx-lib, etc that are provided by freescale. Are these already available in the provided Ubuntu image 12.04? If not how can I go ahead?
I can build all that is needed using yocto projects, bitbake, and freescale provided code, but I dont know how to use the built results. How can I specify board specific stuff? How do I make sure the built image matches this board?
suspension
Return to General discussion
