Broken burn/run switch, fix?
Postby Ahrlad » Tue Mar 24, 2015 8:35 am
My switch for burn/run mode broke last night, and the Matrix is stuck in burn mode, so I can't boot back to openelec. Is there something i can to fix the broken switch, or at least put it in permanent run mode?
Thanks for your help!
Ahrlad
Re: Broken burn/run switch, fix?
Postby smile » Wed Mar 25, 2015 10:45 am
you just need connect two pad with a little wire,like this Picture.Image it will enter RUN mode.
smile
Return to General discussion
