HD audio passthrough
Postby dacman » Sun Feb 01, 2015 10:06 am
Has anyone been able to successfully passthrough HD audio from the TBS Matrix (running Kodi/Openelec) to a processor/receiver? My Marantz AV7005 receives the signal and indicates TruHD (or DTS-MA), but the audio stutters. This happens when playing movies over the network (wired) or off a flash drive plugged into the USB port. I have a high quality HDMI cable running to the Marantz, so I am running out of possibilities. At this point it is either the software build (I have the latest build) or something wrong with my Marantz. I will say the Marantz has no problem accepting regular DD or DTS from the Matrix nor any issues playing HD audio from a Blu-Ray player. I bought the Matrix to replace my Raspberry Pi specifically to be able to play HD audio. Any help would be appreciated.
dacman
Re: HD audio passthrough
Postby ddjpp » Mon Feb 02, 2015 4:02 am
ddjpp
Return to General discussion
