Official, Kodi-based matrixtv
Postby sepinho » Sun Jan 18, 2015 4:24 am
Will there be an official matrixtv release based on Kodi?
I'm asking because I bought a mini PC with a TBS DVB-C/T card and would love to use the latter for live TV within Kodi. As far as I understand it, the OpenELEC builds for the mini PC doesn't support TBS' tuner cards, right? It would be a shame if I would be able to use the tuner in the future.
sepinho
Re: Official, Kodi-based matrixtv
Postby vpeter » Sun Jan 18, 2015 5:07 am
Yes, there will be official build one day.
And those builds will support only cards which are supported in kernel. Only unofficial builds will support more.
vpeter
Postby sepinho » Fri Feb 13, 2015 11:32 pm
Thank you for your reply! Is there a way to use my TBS5881 DVB-C/T2 card with OpenElec yet?
sepinho
Postby vpeter » Fri Feb 13, 2015 11:47 pm
sepinho Wrote:Is there a way to use my TBS5881 DVB-C/T2 card with OpenElec yet?
I don't see driver for arm. So answer is no.
vpeter
Return to General discussion
