Website issue
Website issue
Postby trickymundo » Thu Oct 30, 2014 2:25 am
The fly-out menus on http://www.tbsdtv.com do not appear to work on Firefox. This makes navigation a little difficult. Anyone else experiencing this problem?
It works on IE and Chrome though. Puzzled...
Tricky.
trickymundo
Re: Website issue
Postby warumnix » Thu Oct 30, 2014 10:48 am
Hi trickymundo,
Thanks for the feedback.
It works with Firefox now, please try again and make sure you use the latest Firefox version, and maybe you could also check the settings.
-warumnix
warumnix
Re: Website issue
Postby trickymundo » Fri Oct 31, 2014 1:32 am
I've done a Ctrl-F5 refresh and it is all working now. Thanks for whatever you did. :-)
trickymundo
Return to General discussion
