Can't login over UART.
Postby antonl1911 » Wed Jun 25, 2014 4:19 pm
When MatrixTV is booted, I can't login using COM port of Matrix ARM. It doesn't accepts password for root, like this:
MatrixTv login: root
Password: r
Error: password is incorrect.
So, it doesn't hides first symbol of password when logging in. Connecting over ssh works fine though.
antonl1911
Re: Can't login over UART.
Postby jowski » Thu Jun 26, 2014 1:27 pm
I've had that issue also. I'm still running the original firmware so I think the problem has been around since the beginning. Hopefully someone with later firmware will confirm the issue or report that it has been fixed.
Jim
jowski
Postby steven » Tue Jul 01, 2014 2:40 pm
Hi all
For this problem ,please just wait a few while to login.
or in the u-boot type this command:
setenv bootargs_base 'setenv bootargs console=ttymxc0,115200'
This will let you easy to login but the XBMC will not auto run. when login you can use this command run XBMC
runxbmc
The best way is using SSH to login Matrix.
Return to General discussion
