Using sata hdd
Using sata hdd
Postby Lunigorn » Wed Jun 18, 2014 4:09 pm
I'm using Matrix ARM mini PC (TBS2910) with linux (ubuntu) and I can't plug sata hdd to this device. When I plug in sata hdd to TBS2910, hdd not start vibrate as if I connect it to my home PC on windows. No any device also not show when I plug in sata hdd.
I'm tried connect this device (2 TB) http://www.seagate.com/internal-hard-drives/enterprise-hard-drives/hdd/enterprise-capacity-3-5-hdd/?sku=ST2000NM0033
And this http://www.wdc.com/global/products/specs/?driveID=1092&language=1.
Lunigorn
Re: Using sata hdd
Postby mijanek » Fri Jul 04, 2014 12:34 am
For 3,5'' HDD you will need external power supply providing also 12V. The internal connector is ment only for 2,5'' HDD.
Edit: As I see you got the right answer allready here so my answer is obsolete.
mijanek
Return to General discussion
Users browsing this forum: Google [Bot] and 4 guests
