Two version of MOI Pro will coming soon
Postby steven » Fri Jun 13, 2014 11:47 am
HI All
Two version of MOI Pro will coming soon.
The first one is using
CPU Marvell 88F6282 1.6 GHz (can be updated to 2.0 GHz)
RAM 1GB DDR3 flash
Ethernet 1x /100/1000M Gigabit Ethernet LAN
One PCI-E slot with lots of TBS PCI-E card support (DVB-S DVB-T DVB-C),you can use the one you wan,such as TBS6985 or TBS6991 and so on...
Here is the picture with TBS6991:
With TBS6991
Another one is using
CPU Freescale imx6q quad core 1.0GHz
RAM 2GB DDR3 flash
Two PCI-E slot with lots of TBS PCI-E card support (DVB-S DVB-T DVB-C),you can use the one you wan,such as TBS6985 or TBS6991 and so on...
Here is the picture with TBS6985:
Any advice about these two product will be appreciated. :)
Re: Two version of MOI Pro will coming soon
Postby diabloss » Tue Jun 17, 2014 8:07 pm
The Freescale soc based one looks nice.
2 x Gigabit network interfaces would be an more than awsome addition/feature.
diabloss
Postby steven » Wed Jun 18, 2014 3:02 pm
diabloss Wrote:The Freescale soc based one looks nice.
Hi diabloss
Thanks for your feedback.
Because Freescale only have one Gigabit network.but maybe we can use PCIe interface to use another Gigabit network.:)
Postby gamf » Wed Jun 18, 2014 5:59 pm
Hi Steven,
What I would like is wake on LAN(wol) as well as time based startup from RTC, so a board where a batttery is on the board.
My usecase would be a streaming server which runs if it needs to, so either when a client is switched on, this is why WoL and RTC based for video recordning(timers). And to save energy switch it off or go into deep power sleeps to not drain so much power.
gamf
gamf
Postby apache » Fri Jun 20, 2014 3:15 pm
Hi Steven,
from my point of view WOL is also very important.
It's a pity that the version with 2xPCI-E got weaker CPU.
Also nice enclosure with HDD 2.5" rails would be great.
Do you know when the official version will be released and how much it will be cost?
apache
Postby steven » Tue Jul 01, 2014 2:51 pm
Hi All
Really thanks for the advice,we have already record these good advice. :)
if quickly this month will release the information in our website.
Postby diabloss » Tue Jul 01, 2014 8:26 pm
Hello Steven
Is it possible to have an high quality pcie / usb hybrid sat+cable TBS card?
I mean on same board to have an c/t1/t2 tuner + 1 sat tuner same like the hybrid card from DVBSky.
(do not use for cable tuner the Silabs cable tuner as they do not allow linux kernel drivers)
Thank you
regards
Ovi
diabloss
Postby crazycat » Wed Jul 02, 2014 4:54 am
but latest tbs ter/cab devices also use silabs chips with precompiled binary drivers.
Postby steven » Thu Jul 03, 2014 4:05 pm
diabloss Wrote:Hello Steven
Thank you
regards
Ovi
Hi Ovi
Sorry that here had not the hybrid card now,and i will forward this advice to our hardware department .
Maybe later we will make this card. :)
kind Regards
Postby antonl1911 » Fri Jul 11, 2014 3:29 pm
Why not add HDMI port for those who want to use it as advanced STB? SATA port and HDD enclosure would be greatly appreciated.
antonl1911
Return to General discussion
