Using Wi-Fi in MatrixTV
Postby Fedork » Wed Jun 04, 2014 3:51 pm
Hi guys,
How can I use WLAN in MatrixTV firmware (XBMC)? I need to connect to Wi-Fi network, but I don't know how.
Please, help. Thanks
Fedork
Re: Using Wi-Fi in MatrixTV
Postby Dippo » Thu Jun 05, 2014 6:38 am
Hi Fedork,
When you power on your Matrix you will get a MatrixTV splash screen. When you see this, press the spacebar (or perhaps any key works, I can't remember). You will then see setup options, configure your wifi there.
Hope that helps...
Dippo
Postby Fedork » Sat Feb 21, 2015 4:29 pm
Dippo, thanks a lot!
Fedork
Return to General discussion
