PCM audio channels mixed up
Postby alanb2121 » Thu May 08, 2014 7:00 pm
DD5.1 and DTS pass through works well but when using PCM the channels are mixed up. I.e, center is coming out left rear.
This is a big issue as a lot of sound tracks are AAC which uses PCM as the output to a receiver.
Any word as to when this will be fixed?
alanb2121
Re: PCM audio channels mixed up
Postby steven » Tue May 13, 2014 11:42 am
Hi alanb2121
Thank you very much for this feedback,we will have a check where the problem is now.
Postby alanb2121 » Tue May 13, 2014 4:28 pm
Thanks Steven, I've tried remapping the channels using Alsa but with my limited knowledge in that space I'm not having much luck. I'm hoping its just a driver issue and not a hardware probem
alanb2121
Return to General discussion
