How to configure the TBS 5922 remote to work with XBMC
Postby alanb2121 » Wed Mar 19, 2014 4:35 pm
How to configure the TBS 5922 remote to work with XBMC on the MatrixPC
The first thing you need to do is open up /usr/bin/lircd_pre.sh and change the final line so it reads like this - sed -i "s/^DEVICE=.*/DEVICE=\"\/dev\/lirc1\"/g" /etc/lirc/hardware.conf
This is required in the 1.0.0.4 build as there seems to be a problem with the device it trys to call. it is using lirc0 but needs to be lirc1
Once you have done that perform the following steps,
1. Copy tbs5922.tar (attached) to /etc/lirc/ and rename it to lircd.conf (it's not really a tar file but its the first extension I tried that allowed me to upload the file to the forum, .txt must be evil or something)
2. Copy lircmap.xml to /root/.xbmc/userdata/
3. Copy remote.xml to /root/.xbmc/userdata/keymaps/
A few notes,
You can find a copy of lircmap.xml in /usr/share/xbmc/system. if you use this copy then change the remote device= value to the same name that was used in lircd.conf, I.e remote device="tbs5922"
You can find a copy of remote.xml in /usr/share/xbmc/system/keymaps
I'm no expert at linux so there is probably a smarter way to do this :)
Cheers
tbs5922.tar
(2.57 KiB) Downloaded 605 times
alanb2121
Re: How to configure the TBS 5922 remote to work with XBMC
Postby steven » Thu Mar 20, 2014 4:09 pm
Hi alanb2121
Really thanks for share your way to use remote with XBMC.
You will help the people want to use remote. :)
Postby steven » Mon Apr 07, 2014 2:48 pm
Hi all
This way should be ok with our remote too. :)
Postby sepinho » Wed Apr 16, 2014 4:46 pm
Does this work with all TBS remotes then? It would be great if I could use the one that came with my 5881 DVB card.
sepinho
Postby steven » Tue Apr 29, 2014 5:48 pm
sepinho Wrote:Does this work with all TBS remotes then? It would be great if I could use the one that came with my 5881 DVB card.
yea, TBS5881 use NEC32 remote which is the same as TBS5922 :)
Postby alanb2121 » Tue Apr 29, 2014 6:41 pm
I've tested 1.0.0.6 with the TBS 5922 remote on XBMC and it works great :)
alanb2121
Postby Cjcr » Tue Apr 29, 2014 10:22 pm
@Steven:
Hi, thank you for the update.
I tested with TBS5925 and his remote control and seems that just works key left, key up, key down, key right and vol+. The other commands seems that does nothing.
Cjcr
Return to General discussion
