Power saving
Power saving
Postby gamf » Thu Jan 09, 2014 3:41 am
I got a couple of questions regarding power saving features of the Matrix.
1) What is the typical power consumption in idle?
2) Is it possible to switch the device off from software aka shutdown?
3) Is a RTC included with alarms which can wake the Matrix?
4) Does the board support wake on lan?
Thank you, looking forward to a response
gamf
Re: Power saving
Postby steven » Thu Jan 09, 2014 7:05 pm
Hi gamf
Thank you very much for this good advice.
because Matrix Just released,we are collecting all advice.
then we will start to do what is the user most want. :)
Re: Power saving
Postby apache » Thu Jan 09, 2014 7:48 pm
5) Does usb support hotplug (or every time new USB device is connected Matrix need to be rebooted)?
apache
Re: Power saving
Postby mijanek » Fri Jan 10, 2014 4:17 am
@apache for sure not. I just connected my WD Elemets 500GB 2,5 '' USB HDD and XBMC attached it instantly :-) This works much better than rapsberryPi or so where you have very limited power on USB. I do really love that device (got it 2 days ago 8-) )
mijanek
Re: Power saving
Postby steven » Fri Jan 10, 2014 9:10 am
apache Wrote:5) Does usb support hotplug (or every time new USB device is connected Matrix need to be rebooted)?
Yea,of course, :)
Return to General discussion
