Distribution of several TBS cards in the PCIe of the server.
Postby robertovelasquez » Fri Aug 18, 2023 8:44 am
My server has 5 PCIe in the following order (That is the information that is printed on it):
1) Slot 1 PCIe X16 (16, 8, 4, 1) 75W, EXT 125W
2) 15A/24V
Slot 2 PCIe X8 (4, 1) 25W
3) Slot 3 PCIe X8 (8, 4, 1) 25W
4) 15A/24V
Slot 4 PCIe X16 (16, 8, 4, 1) 75W, EXT 125W
5) Slot 5 PCIe X8 (4, 1) 25W
And I have the following products:
* 2 TBS6209SE cards
* 2 TBS6909-X V2 cards
* 1 10G network card (With 2 ETH ports of 10G each)
What would be the correct order to distribute the 5 mentioned products? so that the efficiency and distribution of energy is correct.
Thanks in advance for any help on this topic.
robertovelasquez
Re: Distribution of several TBS cards in the PCIe of the ser
Postby steven » Tue Aug 29, 2023 10:19 am
Hi Sir,
You can put the 10G ETH card to the slot 1 others you can use our DVB tuners
Return to General discussion
