TBS MatrixTV system update to V1.0.1.1
Postby steven » Wed Oct 29, 2014 10:41 am
Hi All
TBS MatrixTV system has been updated to V1.0.1.1 with following improvements:
News:
1.Add USB disk upate support,more easy to update your Matrix
2.Update to latest XBMC ,fix can not change audio device issue.
3.Update to latest vdr
4.Update to latest dvblast
5.Fix sometimes XBMC black screen issue.
6.Fix some small bugs
Link:
V1.3
http://sourceforge.net/projects/matrixtv/files/Release/MatrixTV/TBS-MatrixTV-V1.0.1.1.zip/download
V2.1
http://sourceforge.net/projects/matrixtv/files/Release/MatrixTV/TBS-MatrixTV-V1.0.1.1-V21.zip/download
any feedback will be appreciated :)
Re: TBS MatrixTV system update to V1.0.1.1
Postby antonl1911 » Wed Oct 29, 2014 3:15 pm
steven Wrote:Hi All
News:
Link:
V1.3
V2.1
What about deinterlacing 1080i streams?
antonl1911
Postby vpeter » Wed Oct 29, 2014 3:46 pm
TBS-MatrixTV-V1.0.1.1-V21 doesn't flash with MfgTool because of same error as last time.
In file cfg.ini there must be changed from
name = SabreSD-eMMC-kernel
to
name = SabreSD-eMMC
vpeter
Postby mikebzh44 » Thu Oct 30, 2014 1:29 am
It's OK for V1.x devices :
[profiles]
chip = MX6Q Linux Update
[platform]
board = SabreSD
[LIST]
name = SabreSD-eMMC
mikebzh44
Postby vpeter » Thu Oct 30, 2014 1:33 am
mikebzh44 Wrote:It's OK for V1.x devices
Yes, previous version was ok also. Only v21 is affected :o
vpeter
Postby mikebzh44 » Thu Oct 30, 2014 1:41 am
No because I have a V1.3 and I had to edit this file according to your post :
viewtopic.php?f=157&t=9165&p=32128#p32135
And with MatrixTV1.0.1.1, I have a MfgTool2 error :
DLL version: 2.2.3
Wednesday, October 29, 2014 18:41:14   Start new logging
ModuleID[2] LevelID[1]: Push command--file D:\Temp\MatrixTV\TBS-MatrixTV-V1.0.1.1\Profiles\MX6Q Linux Update\OS Firmware\files\rootfs.tar.bz2 failed to open.errcode is 2
ModuleID[2] LevelID[1]: Parse ucl script failed, error code: 4
and after renaming Profiles\MX6Q Linux Update\OS Firmware\files\matrix-rootfs.tar.bz2 to rootfs.tar.bz2, it's OK.
mikebzh44
Postby MikeDotBe » Thu Feb 19, 2015 7:42 pm
Is it compatible with box v2.3 ???
Edit : Yes it is :)
MikeDotBe
Postby MikeDotBe » Tue Feb 24, 2015 7:54 am
what is the login password to access the V1.0.1.1 via SFTP ??
MikeDotBe
Postby Dinos52 » Tue Mar 03, 2015 2:22 am
The original Matrix-TV has no (S)FTP-Server. On a Windows PC you can enter the file system via samba. I.e. you should enter the IP of the Matrix in the Windows file explorer like "\\xxx.xxx.xxx.xxx" (without quotes). If you are using WinSCP (recommended), the SCP protocol is the right choice with user/password root/root.
Dinos52
Postby sepinho » Thu Nov 05, 2015 11:46 pm
I guess we won't be seeing any more official matrixtv updates to more current Kodi versions, right? That's sad, because it renders my TBS5881 useless, which I had used for live-tv in earlier xbmc versions.
sepinho
Return to Announcements
