TBS MatrixTV system update to V1.0.0.9 Now
Postby steven » Fri Aug 01, 2014 12:56 pm
Hi All
TBS MatrixTV system has been updated to V1.0.0.9 with following improvements:
News:
1.Fix DTS5.1 audio mix up problem
2.Update to latest wolfgar's XBMC
3.Add USB smart card read support
4.Fix diseqc setup problem
5.Fix some small bugs
There will be two version of firmware one is for the older version one is for the new version.The different is the memory chip.
For older matrix version:
MFG Tools burn:
http://sourceforge.net/projects/matrixtv/files/Release/MatrixTV/TBS-MatrixTV-V1.0.0.9.zip/download
For V2.1 matrix version:
MFG Tools burn:
http://sourceforge.net/projects/matrixtv/files/Release/MatrixTV/TBS-MatrixTV-V1.0.0.9-V21.zip/download
kind Regards
Re: TBS MatrixTV system update to V1.0.0.9 Now
Postby alanb2121 » Mon Aug 04, 2014 8:47 am
Thanks Steven,
Just a correction around the changes made. It wasn't the DTS audio that you fixed but the PCM audio.
Cheers
alanb2121
Postby steven » Mon Aug 04, 2014 2:43 pm
alanb2121 Wrote:Thanks Steven,
Cheers
Hi alanb2121
yea,you are right , :)
Return to Announcements
