TBS MatrixTV system update to V1.0.0.8 Now
Postby steven » Mon Jun 30, 2014 10:03 am
Hi all
TBS MatrixTV system has been updated to V1.0.0.8 with following improvements:
News:
1.Enable the USB hot plug for XBMC
2.Fix some bugs in the setup dialog,such as can not set the language,can not choose the Audio device.
3.Add Windows media center remote support in the IR setup dialog, just choose the one you want to use.
4.Fix some small bugs
There will be two version of firmware one is for the older version one is for the new version.The different is the memory chip.
For older matrix version:
MFG Tools burn:
http://sourceforge.net/projects/matrixtv/files/Release/MatrixTV/TBS-MatrixTV-V1.0.0.8.zip/download
For V2.1 matrix version:
MFG Tools burn:
http://sourceforge.net/projects/matrixtv/files/Release/MatrixTV/TBS-MatrixTV-V1.0.0.8-V21.zip/download
kind Regards
Re: TBS MatrixTV system update to V1.0.0.8 Now
Postby Dippo » Wed Jul 02, 2014 1:19 am
Thanks for this Steven. How can you tell which Matrix you have please ?
Dippo
Postby steven » Mon Jul 07, 2014 4:37 pm
Hi Dippo
Near the Fan and SATA interface there will be a version number
such as V1.3 or V2.1 :)
Postby Dippo » Fri Jul 18, 2014 7:46 pm
Thanks Steven, updated and working well....
Dippo
Return to Announcements
