How to update MatrixTV system through SD card
Postby steven » Wed May 28, 2014 3:47 pm
Hi All
Good news that new version of MatrixTV already add the update from SD card.
Here is the detail information:
If your Matrix runs MatrixTV V1.0.0.7 or a later version, system update becomes more convenient now, you no longer have to connect it via mini USB cable to the PC and then flash the new OS to eMMC, because MatrixTV V1.0.0.7 and the later versions support update through SD card, and there are just a few easy steps!
1. Prepare a SD card (minimum 2GB).
2. Download the latest MatrixTV OS from our website, copy the OS file to the root directory of the SD card.
Like this:
Update Files
3. Insert the SD card to the SD card slot on Matrix, power on Matrix, when it starts to update, the blue LED light is flashing, wait about 5 minutes until the update completes, the blue LED light is then off.
4. Power off Matrix, remove the SD card from Matrix.
5. Power on, your Matrix runs now a newer version of MatrixTV.
Note: Only MatrixTV versions 1.0.0.7 or later support this function.
The PDF file you can download it here:
http://www.tbsdtv.com/download/document ... D-card.pdf
Any question with this ,please reply here :)
Re: How to update MatrixTV system through SD card
Postby franky384 » Thu Sep 25, 2014 6:40 pm
I tried this several times but nothing hapens because there are no files named "uramdisk.img uImage-m".
Can you explane this method step by step ? Please
franky384
Postby steven » Sun Sep 28, 2014 5:49 pm
You can download it on our sourceforge here is the link:
http://sourceforge.net/projects/matrixt ... p/download
we change the uramdisk.img name to uupdata.img :)
uImage-m is the kernel need to be updated.
rootfs-m.tar.bz2 is the file system need to be updated.
These files you can get from mfg burn tool image it is in
TBS-MatrixTV-V1.x.x.x\Profiles\MX6Q Linux Update\OS Firmware\files
rootfs.tar.bz2 is the file system file
uImage is the kernel
uImage and uupdate.img is the update system kernle and file system.
Postby mikebzh44 » Thu Oct 09, 2014 3:51 pm
Sorry to say that but this is not very clear :(
So for upgrading from a SD , we need to download from http://sourceforge.net/projects/matrixt ... /MatrixTV/ :
* MatrixTV-SD3AutoUpdate-Files.zip
* TBS-MatrixTV-V1.x.x.x.zip
Then unzip both files.
In MatrixTV-SD3AutoUpdate-Files, we need to copy uImage and uupdate.img to SD card
In TBS-MatrixTV-V1.x.x.x\Profiles\MX6Q Linux Update\OS Firmware\files, we need to rename uImage to uImage-m and copy it to SD card, copy rootfs.tar.bz2 to SD card
Is that right ?
I think that you PDF need to be refresh : http://www.tbsdtv.com/download/document ... e-V2.1.pdf
mikebzh44
Postby steven » Fri Oct 10, 2014 11:41 am
mikebzh44 Wrote:Sorry to say that but this is not very clear :(
Is that right ?
Thank you so much for your feedback, we will update soon : )
Is that right ?
Later we will release the MatrixTV-SD3AutoUpdate-Files.zip contain the rootfs and uImage : )
Postby mikebzh44 » Tue Oct 14, 2014 5:15 am
I have format a 8 Gb SD card using FAT32 filesystem, then copy files from ZIP :
Insert SD, power on MatrixTV but no flashing blue LED. Only blue and green LED alway ON.
Try with switch on RUN and BURN but same thing.
Is there a way to see which OS version is installed ?
Thanks.
mikebzh44
Postby steven » Tue Oct 14, 2014 2:18 pm
Hi mikebzh44
Please rename rootfs.tar.bz2 to rootfs-m.tar.bz2 is the file system need to be updated. :)
thanks
Postby mikebzh44 » Tue Oct 14, 2014 3:26 pm
Thanks. I will test it this evening.
Do I need to switch from RUN to BOOT/BURN before powering on the MatrixTV with SD card in ?
BTW, how I can I know the version number of my current OS ? Is there a command I can send by SSH ? Or a file I can read ? Or is it displayed in XBMC or at boot time ?
mikebzh44
Postby steven » Tue Oct 14, 2014 4:03 pm
Hi mikebzh44
no ,you do not need to change to burn mode just the normal boot mode.
In XBMC status dialog you can see the build date. : )
and when you login with SSH you can see the build date too.
Return to Announcements
