TBS MatrixTV system update to V1.0.0.7
Postby steven » Tue May 27, 2014 6:16 pm
Hi all
TBS MatrixTV system has been updated to V1.0.0.7 with following improvements:
News:
1.Add Auto update from SD card support.(need to use latest MatrixTV newer than V1.0.0.7) ,next update will use this way to update. :)
just need to copy the update files to SD card root folder.plug to Matrix's SD card slot,power on then it will auto update.
2.Fix the HDMI-CEC can not use when unplug and plug HDMI cable.
3,Add HDMI-HDR support
4.Fix some small bugs
Here is the download link:
http://sourceforge.net/projects/matrixt ... p/download
kind Regards
Re: TBS MatrixTV system update to V1.0.0.7
Postby Dippo » Wed May 28, 2014 12:27 am
Hi Steven,
Thanks for providing us with continuous updates.
It's great to see the functionality improving each time...
Dippo
Postby alanb2121 » Thu May 29, 2014 5:18 am
Thanks for the update Steven.
Have you fixed the problem with PCM audio channels being mixed up?
alanb2121
Postby steven » Fri May 30, 2014 11:43 am
alanb2121 Wrote:Thanks for the update Steven.
Hi alanb2121
Would you mind provide the audio file you are using.then i will have a try with myself. : )
Postby alanb2121 » Fri May 30, 2014 1:37 pm
Just run the sound setup from the initial setup menu on boot. Select HDMI and full 5.1 You will see that center comes out of left rear and left rear comes out of center. Alternatively start any movie in XBMC that uses AAC for its sound format, or run sound-test from a command prompt. I'm no expert but i assume this can be fixed by configuring Alsa correctly.
alanb2121
Postby luistobcn » Tue Jun 03, 2014 8:31 pm
hi, this version works Oscam?
luistobcn
Return to Announcements
