TBS MatrixTV system update to V1.0.0.6-2
Postby steven » Fri May 09, 2014 2:47 pm
Hi all
TBS MatrixTV system has been updated to V1.0.0.6-2 with following improvements:
News:
1.The blue light will flash three times and the fan will turn on a while when booting. (with this can easy check whether Matrix is on running )
2.Fix the Diseqc problem .
3.Update to latest wolfgar's XBMC
4.Fix some small bug
Here is the download link:
http://sourceforge.net/projects/matrixt ... p/download
kind Regards
Re: TBS MatrixTV system update to V1.0.0.6-2
Postby luistobcn » Fri May 09, 2014 10:42 pm
Thank steven.
the DiSEqC setting works well,and vdr dvb-s2 fta working.
But I need it to work with Softcam (oscam)in VDR or Theaden(It is the real reason why buy the Matrix and tbs 5980 dvb-s2)
Is it possible softcam in tvmatrix run in the future?
Thanck
luistobcn
Postby diabloss » Sat May 10, 2014 2:55 pm
Hello Steven
I had no luck to install and setup the vdr-sc package.
Can you guys take in consideration to enable / insert by default the usage of vdr-sc in the next Matrix TV software 1.0.0.7 ?
best regards
diabloss
Postby alanb2121 » Sun May 11, 2014 6:34 am
diabloss Wrote:Hello Steven
best regards
Yes please
alanb2121
Postby diabloss » Thu May 15, 2014 6:10 pm
VDR-SC seems to be broken with vdr 2.0.0 so mostlikely will take some time till fix.
diabloss
Return to Announcements
