Help! problème impossible d'éteindre Matrix
Postby amine2014 » Wed Mar 26, 2014 5:16 pm
Bonjour communauté Matrix. Help!
Je viens de recevoir mon matrix et le bouton power ne marche pas, et quand je veux arrêter xbmc ça reste bloqué sur éteindre, c'est un bug. :cry:
Merci
Cordialement,
amine2014
Re: Help! problème impossible d'éteindre Matrix
Postby steven » Thu Mar 27, 2014 3:26 pm
Hi amine2014
We have already found this problem is caused by the HDMICEC libs,if you rename all the libcec* to another name.
It will be ok.
and we are working on this too.
any progress we will let you know as soon as possible.
Postby steven » Thu Mar 27, 2014 4:04 pm
Hi amine2014
It will be ok.
Postby amine2014 » Thu Mar 27, 2014 10:01 pm
hello
How to rename all libcec? A tutorial is that possible?
Thank you for your reply.
cordially
amine2014
Postby steven » Mon Mar 31, 2014 11:25 am
Hi amine2014
You can login Matrix with SSH, and the you can use find command to find all the libcec files.
Like this:
[root@matrixtv /]# find / -name libcec*
/usr/lib/libcec.so
/usr/lib/libcec.so.2
/usr/lib/libcec.so.2.0.1
/var/lib/opkg/info/libcec.control
/var/lib/opkg/info/libcec.list
/media/mmcblk0p1/usr/lib/libcec.so
/media/mmcblk0p1/usr/lib/libcec.so.2
/media/mmcblk0p1/usr/lib/libcec.so.2.0.1
/media/mmcblk0p1/var/lib/opkg/info/libcec.control
/media/mmcblk0p1/var/lib/opkg/info/libcec.list
[root@matrixtv /]#
Just rename all these files to another name
Postby maxi1978 » Wed Apr 09, 2014 4:34 am
What about people who do not no how to do this?
There is no info about this at all,i would of thought this
Would of been one off the first things to get done a working on/off.
maxi1978
Postby updatelee » Wed Apr 09, 2014 6:31 am
rename files with the mv command.
mv /old_path/old_filename /new_path/new_filename
Return to Announcements
