TBS MatrixTV system update to V1.0.0.4
Postby steven » Wed Mar 12, 2014 5:37 pm
Hi all
TBS MatrixTV system has been updated to V1.0.0.4 with following improvements:
News:
1.Using latest woflgar's XBMC.
2.Update the scan-s2 tool fix some HD channel can not play by VDR.
3.Merge wolfgar latest kernel patch.
4.Can change the resolution in XBMC.
5.Fix some small bugs.
http://sourceforge.net/projects/matrixt ... p/download
Any feedback will be welcome. :)
Re: TBS MatrixTV system update to V1.0.0.4
Postby Cjcr » Thu Mar 13, 2014 10:47 pm
steven Wrote:Hi all
News:
Thank you Steven,
I not tried it yet, but it is based on the latest https://github.com/xbmc-imx6 branch?
Cjcr
Postby mijanek » Fri Mar 14, 2014 2:59 am
@Cjcr yes, it contains the same build like I made last time..
mijanek
Postby mijanek » Fri Mar 14, 2014 4:28 am
Hi Steven,
I made a test to this build. You have still buggy config for xbmc inside resulting with black screen, so everyone who is testing it, just remove the xbmc config by issuing following command:
rm -r /root/.xbmc
Sofar it is the best state for XBMC experience :-)
Bye
Miro
mijanek
Postby Cjcr » Fri Mar 14, 2014 4:29 am
mijanek Wrote:@Cjcr yes, it contains the same build like I made last time..
Oh great!
I want to ask you before reporting if the WMV files work for you?
I tried one wmv I have somewhere and it plays audio but shows a static frame.
Cjcr
Postby mijanek » Fri Mar 14, 2014 4:33 am
Cjcr Wrote:I want to ask you before reporting if the WMV files work for you?
If you have some link, with the test file, I can have a try.. I don't have any wmv files...
mijanek
Postby Cjcr » Fri Mar 14, 2014 4:37 am
Unfortunately it contains family stuff and I can't share it, but if I find any other with the same problem I'll share it, of course.
Cjcr
Postby diabloss » Sat Mar 15, 2014 11:58 pm
some thoughts on 1.0.0.4
looks stable and working fine so far.
the image glitches while run live tv + xbmc menu still there till xbmc menu is closed.
having some small random issues with subtitle services (but this is an addon error )
@steven
vdr + oscam seems to be set by default to work only with dvbapi.
i tried several times to make vdr to connect to oscam via vdr-sc plugin but without any luck.
i need vdr to read from a remote oscam server via newcamd protocol and this is posible only with vdr-sc plugin is set to work alone without dvbapi.
diabloss
Postby mijanek » Sun Mar 16, 2014 4:29 am
diabloss Wrote:i need vdr to read from a remote oscam server via newcamd protocol and this is posible only with vdr-sc plugin is set to work alone without dvbapi.
Just configure the local oscam to connect to your remote oscam proxy... that way is it much better then vdr-sc client. I would never go back for vdr-sc wich is loosing emms...
mijanek
Postby steven » Thu Mar 20, 2014 4:56 pm
Because our setup dialog is not very well now. the default CAM use is not OSCAM ,Later we will add option to let user choose
use OSCAM or the really CAM device with our cards. :)
Return to Announcements
