TBS MatrixTV system update to V1.0.0.3-1
Postby steven » Tue Feb 18, 2014 3:00 pm
Hi all
Sorry that V1.0.0.3 still have some diseqc problem.so we update a new one V1.0.0.3-1 ,
Here is the download link:
http://sourceforge.net/projects/matrixtv/files/Release/MatrixTV/TBS-MatrixTV-V1.0.0.3-1.zip/download
TBS MatrixTV system has been updated to V1.0.0.3 with following improvements:
1.Use wolfgar latest XBMC which fixed a lot of problem especially about the HD .Thank you very much for the effort made by wolfgar. :)
2.Add TBS USB tuner support for the following products:
TBS 5990 Dual DVB-S/S2 CI BOX
TBS 5280 DVB-T/C
TBS 5281 DVB-T/C
3.Merge wolfgar latest kernel update.
4.Fix Diseqc Setup can not scan low band issue
5.Fixe some small bugs
In this package already include the DVB-T and DVB-C kernel,In burn tool Profiles\MX6Q Linux Update\OS Firmware\files folder. :)
If you want to use the DVB-T just rename the uImage_DVBT_20140217 file to uImage.
or DVB-C uImage_DVBC_20140217 to uImage
Any feedback will be welcome. :)
Re: TBS MatrixTV system update to V1.0.0.3
Postby piotrasd » Wed Feb 19, 2014 7:35 am
some DVI fix there are ?
piotrasd
Postby steven » Wed Feb 19, 2014 2:12 pm
piotrasd Wrote:some DVI fix there are ?
Next version we will be fix this ,we will have more test with this.
Re: TBS MatrixTV system update to V1.0.0.3-1
Postby bzoli72 » Fri Feb 21, 2014 10:53 pm
steven Wrote:Hi all
TBS 5280 DVB-T/C
TBS 5281 DVB-T/C
Hi steven!
DiSEqC config is OK.
Channel scanning with TBS5925 is OK.
Oscam configured and work.
Scrambled channel is not OK.
vdr-plugin-DVBAPI missing or not work correctly.
In XBMC Output resolution and freqency not adjustable.
24P mkv movies freeze with 60P Output frequency.
bzoli72
bzoli72
Return to Announcements
