HDMI - DVI - issue
HDMI - DVI - issue
Postby piotrasd » Thu Feb 06, 2014 2:55 am
There is problem with MatrixTV connected over cable HDMI -> DVI to monitor or TV
(always start with resolution 640x480 even if we try change in bootloader resolution)
On raspberrypi there is no issue when im using this same cable.
I read something about DVI and i.MX6 and there is few patches for that
https://github.com/boundarydevices/u-bo ... 59ed4c4bb2
https://github.com/boundarydevices/linu ... e0b2f6ecd4
https://github.com/Freescale/meta-fsl-a ... tors.patch
nice will be if developers of TBS add this to next OS version
piotrasd
Re: HDMI - DVI - issue
Postby steven » Sun Feb 09, 2014 2:52 pm
Hi Piotrasd
Thank you very much for this feedback.
we will have more check with this.and do you have the interest to have a try with the beta
kernel and u-boot which added the DVI support. :)
you can send the PM message to me if you want to have a try with the beta version.
Return to Announcements
