TBS MatrixTV system update to V1.0.0.1 Now
Postby steven » Fri Jan 10, 2014 7:35 pm
Hi all
TBS MatrixTV system update to V1.0.0.1 ,which has the following updates.
1.Fix when using Analog audio XBMC have noise problem
2.Update wolfgar's latest XBMC to 13.0.alpha12
3.Update VDR to 2.1.3
4.Fix the Fan noise problem:
the fan is off and stay silent when the temperature is under 70°C, it will be on when the temperature reaches 70°C.
otherwise the will power off.
5.Fix other small bugs.
Here is the download linker :
http://sourceforge.net/projects/matrixt ... p/download
Any feedback will be welcome. :)
Re: TBS MatrixTV system update to V1.0.0.1 Now
Postby mijanek » Fri Jan 10, 2014 7:54 pm
Thanks, I'll try it out this weekend!
mijanek
Return to Announcements
