!SOLVED! TBS driver package and TT-USBIR
Postby WhatIcanDo » Sat Apr 12, 2014 2:19 am
I am using yaVDR distro and now I bought TBS6285 card. But I have problem. When I make TBS drivers I lost my TT-USBIR usb irda (
Technotrend Remote USB-IR).
[   15.087096] lirc_dev: IR Remote Control driver registered, major 250
[   15.116644] lirc_ttusbir: module is from the staging directory, the quality is unknown, you have been warned.
[   15.116678] lirc_ttusbir: disagrees about version of symbol lirc_register_driver
[   15.116681] lirc_ttusbir: Unknown symbol lirc_register_driver (err -22)
How I can prevent that? Because when I install linux-media-dkms -package I got my TT-USBIR working but card got missing.
Seems that TBS drivers overwrite those working modules/drivers. I tried make menuconfig and disabled TechnoTrend items but still when I intall TBS drivers tt-usbir is not working.
lsusb
Bus 003 Device 002: ID 0b48:2003 TechnoTrend AG
sudo modprobe lirc_ttusbir
FATAL: Error inserting lirc_ttusbir (/lib/modules/3.2.0-60-generic/kernel/drivers/staging/media/lirc/lirc_ttusbir.ko): Invalid argument
WhatIcanDo
Re: TBS driver package and TT-USBIR
Postby WhatIcanDo » Sat Apr 12, 2014 10:41 pm
I tested remove /lib/modules/xxx/kernel/drivers/media but that didn't help me.
So I will try install linux-media-dkms package and after that copy those lirc modules to safe. Aftet TBS Driver installation I will try to use those old ones.
Edit. Didn't get working.
WhatIcanDo
Postby WhatIcanDo » Sun Apr 13, 2014 2:07 am
I found solution.
Before make, I need run make menuconfig and enable TTUSBIR module. After that card and remote is working.
WhatIcanDo
