Install TBS 6280 Driver on Ubuntu 14.04.6 LTS X64
Postby xunil2003 » Sat Dec 07, 2019 7:12 am
I am French, excuse me if I express myself badly.
I am on Kubuntu
14.04.6 LTS X64
Core :
 4.4.0-148-generic
During the installation of the TBS v170330 driver of the TBS 6280, I have an error 2.
cd /home/laurent/pilotes/tbs-linux-drivers_v170330/linux-tbs-drivers
[b]sudo ./v4l/tbs-x86_64.sh[/b]
sudo make
  CC [M]  /home/laurent/pilotes/tbs-linux-drivers_v170330/linux-tbs-drivers/v4l/saa716x_input.o
In file included from <command-line>:0:0:
/home/laurent/pilotes/tbs-linux-drivers_v170330/linux-tbs-drivers/v4l/compat.h:504:0: warning: "BIT" redefined [enabled by default]
 #define BIT(x)  (1UL<<((x)%BITS_PER_LONG))
In file included from include/linux/bitops.h:4:0,
                 from include/linux/kernel.h:10,
                 from include/linux/list.h:8,
                 from include/linux/preempt.h:10,
                 from include/linux/spinlock.h:50,
                 from include/linux/seqlock.h:35,
                 from include/linux/time.h:5,
                 from include/linux/input.h:11,
                 from /home/laurent/pilotes/tbs-linux-drivers_v170330/linux-tbs-drivers/v4l/compat.h:9,
include/linux/bits.h:6:0: note: this is the location of the previous definition
 #define BIT(nr)   (1UL << (nr))
make[3]: *** Pas de règle pour fabriquer la cible « /home/laurent/pilotes/tbs-linux-drivers_v170330/linux-tbs-drivers/v4l/tbsctrl.o », nécessaire pour « /home/laurent/pilotes/tbs-linux-drivers_v170330/linux-tbs-drivers/v4l/saa716x_tbs-dvb.o ». Arrêt.
make[2]: *** [_module_/home/laurent/pilotes/tbs-linux-drivers_v170330/linux-tbs-drivers/v4l] Error 2
make[2]: Leaving directory `/usr/src/linux-headers-4.4.0-148-generic'
make[1]: *** [default] Erreur 2
make[1]: quittant le répertoire « /home/laurent/pilotes/tbs-linux-drivers_v170330/linux-tbs-drivers/v4l »
make: *** [all] Erreur 2
sudo make install
make -C /home/laurent/pilotes/tbs-linux-drivers_v170330/linux-tbs-drivers/v4l install
make[1]: entrant dans le répertoire « /home/laurent/pilotes/tbs-linux-drivers_v170330/linux-tbs-drivers/v4l »
Removing obsolete files from /lib/modules/4.4.0-148-generic/kernel/drivers/media/dvb/frontends:
Removing obsolete files from /lib/modules/4.4.0-148-generic/kernel/drivers/media/common:
Removing obsolete files from /lib/modules/4.4.0-148-generic/kernel/drivers/media/IR:
Removing obsolete files from /lib/modules/4.4.0-148-generic/kernel/drivers/media/IR/keymaps:
Removing obsolete files from /lib/modules/4.4.0-148-generic/kernel/drivers/media/dvb/cinergyT2:
Removing obsolete files from /lib/modules/4.4.0-148-generic/kernel/drivers/media/video:
Distro kernel with a non-standard place for modules detected.
Removing old/obsolete LUM files from /lib/modules/4.4.0-148-generic//updates/dkms:
Installing kernel modules under /lib/modules/4.4.0-148-generic/kernel/drivers/media/:
/sbin/depmod -a 4.4.0-148-generic
make -C firmware install
make[2]: Entering directory `/home/laurent/pilotes/tbs-linux-drivers_v170330/linux-tbs-drivers/v4l/firmware'
Installing firmwares at /lib/firmware: vicam/firmware.fw dabusb/firmware.fw dabusb/bitstream.bin ttusb-budget/dspbootcode.bin cpia2/stv0672_vp4.bin av7110/bootcode.bin
make[2]: Leaving directory `/home/laurent/pilotes/tbs-linux-drivers_v170330/linux-tbs-drivers/v4l/firmware'
Is the v170330 driver very recent for Linux Ubuntu 14.04.6 ?
Thank you in advance for your help is notice.
xunil2003
Re: Install TBS 6280 Driver on Ubuntu 14.04.6 LTS X64
Postby steven » Tue Dec 10, 2019 10:16 am
Hi Sir
Please use this package :
# wget http://www.tbsdtv.com/download/document/linux/media_build-2019-11-01.tar.bz2
#tar jxvf media_build-2019-11-01.tar.bz2
#cd media_build
#./install.sh
#reboot
