tvheadend 4.2.6-16 dont detect card
Postby wynasoft1 » Tue Aug 14, 2018 10:39 am
Hi guys after update tvheadend to this build 4.2.6-16 my card is not detected anymore anyone have this issue any experience please?
thanks
regards
wynasoft1
Re: tvheadend 4.2.6-16 dont detect card
Postby steven » Tue Aug 14, 2018 2:22 pm
Please send your dmesg | grep frontend log to us have a check
when you update tvheadend do you have update the kernel too ? is yes you need to reinstall the driver again
Postby wynasoft1 » Thu Aug 16, 2018 12:49 am
thanks for reply Steven i did update kernel too anyway card was working after that when i notice that card was not detected anymore i did drivers reinstallation and nothing also i did clean drivers and resinstall again and nothing i move card to other port and nothing dmesg | grep cx23885 reply nothing so card is dead or what can i do?
attached full log of system.
thanks
dmesg.zip
(19.05 KiB) Downloaded 373 times
wynasoft1
Postby steven » Thu Aug 16, 2018 11:12 am
Can you send the
lspci -vvv log to us have a check too
from dmesg there is no driver init for your tuner card
thanks
kind Regards
Postby wynasoft1 » Fri Aug 17, 2018 2:22 am
attached
thanks
regards
lspci.zip
(7.53 KiB) Downloaded 356 times
wynasoft1
Postby steven » Wed Aug 22, 2018 3:22 pm
From the lspci log it is like your PChave not detect your 6285,is this pc detect your 6285 before ?
if yes please have a try take out the 6285 and inser to another PCI-E slot check whether is ok
you can using command
#lspci -vvv | grep 6285
check whether you PC find the 6285
if still can not detect maybe the card is broken you can you try in another PC
