Struggle to install drivers for 6982
Postby Monstamac » Thu Dec 17, 2020 10:26 pm
Hi, I bought a 6982 Second hand off ebay. I have got it working but it was a struggle.
Firstly, there are no downloads for linux listed on the TBS page, and its not clear what you should load if you havent used a TBS product before.
I have tried Ubuntu 20, Debian 9 and Debian 10 to get it working to see if it was a distro problem
I followed the instructions below ( after installing the kernel sources & headers and various software that was required )
from https://github.com/tbsdtv/linux_media/wiki
The first time I tried it compiled with errors, I then tried ./install.sh a second time and it worked.
This is very confusing
What am I doing wrong ? Is there a more complete guide to installing TBS cards ?
I also cant get the card to work with another card at the same time which I have written a post about.
#wget http://www.tbsdtv.com/download/document ... 04.tar.bz2
#tar jxvf media_build-2020-12-04.tar.bz2
#cd media_build
#./install.sh
#reboot
Monstamac
Re: Struggle to install drivers for 6982
Postby steven » Fri Dec 18, 2020 9:49 am
Hi Sir
Thanks so much for your feedback we will update the download page.
