6982 Tuner Card Problem With Freesat
Postby ArferDaley » Thu Jun 09, 2016 10:02 am
hi all since the reorder of the free-sat and channel five going HD I am now having problems
a lot of the channels now only have now and next EPG is their a fix for this I have emailed TBS no answer I really don't want to Bin TBS and move too another pctv card make as up till now I have had excellent service for the past few years anyone advise please I am on windows 7 Pro 64Bit thru windows media centre my
my TBS6280 on free-view is still banging away perfect with all epg info
any help would be grateful
ArferDaley
Re: 6982 Tuner Card Problem With Freesat
Postby DVB » Fri Jun 10, 2016 12:09 pm
DVB card is only receiving signal and passing stream to application. Thus DVB card got no impact on EPG content. EPG is loaded by application that You are using for watching TV.
Freesat is using its own EPG standard referenced often as Freesat EPG, if You want to see EPG You have to find DVB player that is able to read Freesat EPG.
Changing DVB card to other won't help, because it's not DVB card problem, but DVB player problem.
And now you're watching 8K:
KKKKKKKK
DVB
