help i am running TBS6280 Can I install In Same PcTBS698
Postby ArferDaley » Sat Sep 28, 2013 9:06 am
hi will the above cards co exist in the same machine or will their be some problems when I try too install the new TBS6982
I have been emailing your tec dept all week no answer as of yet new card due to arrive any day now :roll:
ArferDaley
Re: help i am running TBS6280 Can I install In Same PcTBS69
Postby ArferDaley » Sun Sep 29, 2013 3:55 am
these forums are the same as your technical support USELESS
ive cancelled the card i ordered rather than run the risk of not being able too get support when u need it
looks like back to avermedia at least they answer emails
ArferDaley
Postby steven » Wed Oct 02, 2013 10:36 pm
Do you mean that you want to use TBS6282 and TBS6982 at the same machine??
If it is like this.It is ok.no problem
