Where can I get it to test this device.
Postby ashdodmiracle » Mon Aug 19, 2013 3:57 pm
Can I buy it to get test?
I use today two separate card's: 6922 & 6923.
Location: middle east. Receive: 4W, 5E, 9E, 13E, 36E, 53E, 75E.
Diseqc 1.1 8x1 two pieces.
Both cards are petty good, but some transponders work better on 23, and other on 22. (if they work separately)
Lot of the problems today is when both card's on same LNB (lnb is twin), If I locate both cards on same transponder - they may crash (depending on the signal strength), when separately on this transponder they work ok.
I want to test 8922, maybe in this device this problem is resolved.
TBS6922, TBS6923. 4W, 4.8E, 9E, 13E, 36E, 53E, 75E.
Previous cards: TBS8910, TBS8920, Qbox(ii), TBS6921
ashdodmiracle
Re: Where can I get it to test this device.
Postby updatelee » Mon Aug 19, 2013 8:13 pm
a twin lnb has no concept of what freq is being tuned, if two identical freq are being tuned the lnb is oblivious to this. It cant be anything more then a coincident.
Postby ashdodmiracle » Tue Aug 20, 2013 2:39 am
The point is on drivers, two cards on one system has some bug's when work together. Maybe dual tuner resolve this problem.
ashdodmiracle
Postby ashdodmiracle » Sat Aug 31, 2013 6:41 pm
Can you confirm genuine item on this site?:
http://www.aliexpress.com/item/100-Guar ... 03391.html
ashdodmiracle
