MSI Z170A PC MATE TBS6982 CARD
Postby necofon » Sat Aug 11, 2018 6:50 am
I made the bios update of the MSI z170 pc mate motherboard. my TBS6982 TV card did not work, Windows did not see it, I changed the slot and tried the same TV card again with another computer. The old z170a pc mate (bios) version works when installed.
The new MSI z170a pc Mate(bios) version does not work when installed
new bios the TV card isn't recognized
necofon
Re: MSI Z170A PC MATE TBS6982 CARD
Postby steven » Tue Aug 14, 2018 2:23 pm
Please have a try set the PCI-E link speed to Gen1 ,for 6982 it is using NXP7160 PCI-E bridge which is PCI-E 1.0a ,some motherborad have not
add 1.0a support in BIOS so need the motherboard to update the BIOS support.
Or you can have a look at our TBS6902 which is using new PCI-E bridge.
https://www.tbsiptv.com/tbs6902-dvb-s2- ... -pcie-card
