TBS 6908 Help
TBS 6908 Help
Postby savskii » Mon Mar 23, 2015 10:40 pm
Hi there, sorry if this has been covered before as i cant find a solution.
I have a TBS 6908 using linux Ubuntu all drivers etc are ok and i can lock normal frequencies but on 5w or 13E when it comes to these tps i below i get a 90% signal lock but i cant tune any channels:
5W
12648.00 V DVB-S2 PLS: Gold+121212 8PSK ACM/VCM Stream 1 29500 8/9
I have tryed mumudvb, scan, scan-s2, astra, dvblast and all do the same
Any help would be appriciated
savskii
Re: TBS 6908 Help
Postby smile » Wed Mar 25, 2015 11:35 am
Hi savskii ,
There is a multistream in this frequency.maybe need input the stream number.There is necessary on the windows system.so I think maybe at the same on linux .
Best Wishes
smile
Re: TBS 6908 Help
Postby savskii » Thu Mar 26, 2015 8:05 pm
smile Wrote:Hi savskii ,
Best Wishes
Hi Smile thanks for your reply...
Enter multistream how? and where?
cheers
savskii
Re: TBS 6908 Help
Postby crazycat » Fri Mar 27, 2015 12:31 am
Current linux drivers not support mis/pls control.
