TBS6985 Quad Tuner PCIe driver installation error
Postby buttu2000 » Mon Sep 29, 2014 8:45 am
Hello, I have two TBS6985 Quad Tuner PCIe Cards fitted on my PC
try to install the linux drivers for both cards on my ubuntu server 32 bit:
Description: 14.04.1 LTS
Release: 14.04
Code name: trusty
uname -a
Linux Bary 3.13.0.24-generic #46-Ubuntu SMP Thu Apr 10 19:08:14 UTC 2014
i686 i686 i686 GNU/Linux
I have tried the Linux driver tbs-linux-drivers_v140819 and tbs-linux-drivers_v140707 but
unforuntly both of them didnt work.
I had followed the below procedure to install the drivers:
1- Login on terminal as root (sudo su)
2- Create a folder on root tbs (/root/tbs)
3- Copied the tbs-linux-drivers_v140707 to /root/tbs
4-
cd /root/tbs
5-
unzip tbs-linux-drivers_v140707
6- extract linux-tbs-drivers.tar.bz2 archive:
7- cd linux-tbs-drivers
8- Run the command:
./v4l/tbs-x86_r3.sh
9- build and install the driver
make && make install
10- reboot in order to load the newly installed driver:
shutdown -r now
After restart I run the command:
dmesg | grep cx88
but no output at all
When trying the command
dmesg | grep frontend
below is the output
[ 10.317842] saa716x_core: disagrees about version of symbol dvb_frontend_detach
[ 10.317843] saa716x_core: Unknown symbol dvb_frontend_detach (err -22)
[ 10.317851] saa716x_core: disagrees about version of symbol dvb_unregister_frontend
[ 10.317853] saa716x_core: Unknown symbol dvb_unregister_frontend (err -22)
[ 10.317857] saa716x_core: disagrees about version of symbol dvb_register_frontend
[ 10.317859] saa716x_core: Unknown symbol dvb_register_frontend (err -22)
[ 10.328705] saa716x_core: disagrees about version of symbol dvb_frontend_detach
[ 10.328706] saa716x_core: Unknown symbol dvb_frontend_detach (err -22)
[ 10.328715] saa716x_core: disagrees about version of symbol dvb_unregister_frontend
[ 10.328717] saa716x_core: Unknown symbol dvb_unregister_frontend (err -22)
[ 10.328721] saa716x_core: disagrees about version of symbol dvb_register_frontend
[ 10.328723] saa716x_core: Unknown symbol dvb_register_frontend (err -22)
dmesg > dmesg.log
https://www.dropbox.com/s/nb35tdsssvz6h ... g.log?dl=0
lspci -vvnn >> lspci_log
https://www.dropbox.com/s/7np0zko3h6kz3 ... i_log?dl=0
my kernel.log
sudo cat /var/log/kern.log > kernel.log
https://www.dropbox.com/s/agsyvc2srrazm ... l.log?dl=0
the goal is to the following:
1- Configure the right drivers for the the above two TBS6985 Quad Tuner on my PC.
please someone can help me ? with right drivers and procedure.
Buttu
buttu2000
Re: TBS6985 Quad Tuner PCIe driver installation error
Postby buttu2000 » Mon Sep 29, 2014 10:46 am
Thanks to support@tbsdtv.com , here is reply:
Please check the FAQ file inside the driver package tbs-linux-drivers_v140819.zip , you will find the solve solution.
Thanks!
and of the FAQ find the following:
TBS Linux FAQ
Q1. after the drivers are installed there are error messages like:
"disagrees about version of symbol..."
and/or
"Unknown symbol..."
on 'dmesg' output and no DVB devices are created.
A1: do the following:
# sudo rm -rf /lib/modules/<kernel_version>/kernel/drivers/media/
where "<kernel_version>" is replaced by the loaded kernel version
and then reinstall the drivers with doing "make install".
TBC
EOF
So basically I fellow the instruction and good now.
dmesg | grep dvb
[ 10.532502] Modules linked in: ir_mce_kbd_decoder(OF+) saa716x_core(OF) ir_sony_decoder(OF) tbs6922fe(POF) tbs6928fe(POF) tbs6991se(POF) tbs6290fe(POF) stv090x(OF) kvm_intel(-) dvb_core(OF) ir_jvc_decoder(OF) kvm ir_rc6_decoder(OF) snd ir_rc5_decoder(OF) i915(+) ir_nec_decoder(OF) serio_raw rc_core(OF) lpc_ich soundcore drm_kms_helper tpm_infineon drm mei_me video wmi mac_hid parport_pc mei i2c_algo_bit ppdev lp parport usb_storage hid_generic usbhid hid e1000e ptp ahci psmouse libahci pps_core
[ 11.528344] DVB: registering new adapter (SAA716x dvb adapter)
[ 12.237273] DVB: registering new adapter (SAA716x dvb adapter)
[ 12.788922] DVB: registering new adapter (SAA716x dvb adapter)
[ 13.340995] DVB: registering new adapter (SAA716x dvb adapter)
[ 13.912580] DVB: registering new adapter (SAA716x dvb adapter)
[ 14.464956] DVB: registering new adapter (SAA716x dvb adapter)
[ 15.016972] DVB: registering new adapter (SAA716x dvb adapter)
[ 15.572952] DVB: registering new adapter (SAA716x dvb adapter)
buttu2000
