Card not recognized
Card not recognized
Postby limiteddi » Thu Apr 03, 2014 10:44 pm
Driver install went well. 4 quad cards in system:
Here are the outputs
dmesg | grep frontend
[    6.903819]  [<ffffffffa040c28e>] ? saa716x_tbs6985_frontend_attach+0x21f/0x2df [saa716x_tbs_dvb]
and "dmesg | grep tbs" shows
[    5.797177] tbs6991se: module license 'TurboSight Proprietary: www.tbsdtv.com' taints kernel.
[    6.392017] Registered IR keymap rc-tbs-nec
[    6.894491]  tbs6985fe - attach failed
[    6.900007] IP: [<ffffffffa02dc029>] tbsfe_attach+0x3/0xfda [tbsfe]
[    6.900299] Modules linked in: tbsfe(O) tbs6985fe(P) rc_tbs_nec(O) saa716x_tbs_dvb(O+) tbs6982fe(P) tbs6680fe(P) tbs6923fe(P) tbs6985se(P) tbs6928se(P) ir_lirc_codec(O) tbs6982se(P) lirc_dev(O) radeon snd_pcm tbs6991fe(P) ir_mce_kbd_decoder(O) tbs6618fe(P) ir_sony_decoder(O) saa716x_core(O) ir_jvc_decoder(O) snd_page_alloc snd_timer snd soundcore ttm drm_kms_helper drm tbs6922fe(P) ir_rc6_decoder(O) tbs6928fe(P) ir_rc5_decoder(O) tbs6991se(P) ir_nec_decoder(O) stv090x(O) dvb_core(O) rc_core(O) power_supply i7300_edac i2c_algo_bit iTCO_wdt iTCO_vendor_support edac_core dcdbas i2c_core coretemp psmouse rng_core serio_raw pcspkr evdev processor shpchp button thermal_sys ext4 crc16 jbd2 mbcache sg sr_mod sd_mod ses cdrom crc_t10dif enclosure ata_generic uhci_hcd ata_piix libata ehci_hcd usbcore usb_common bnx2 megaraid_sas scsi_mod [last unloaded: scsi_wait_scan]
[    6.902953] RIP: 0010:[<ffffffffa02dc029>]  [<ffffffffa02dc029>] tbsfe_attach+0x3/0xfda [tbsfe]
[    6.903819]  [<ffffffffa040c28e>] ? saa716x_tbs6985_frontend_attach+0x21f/0x2df [saa716x_tbs_dvb]                                                      [    6.903819]  [<ffffffffa040ff51>] ? saa716x_tbs_pci_probe+0x249/0x294 [saa716x_tbs_dvb]        [    6.903819]  [<ffffffffa040ff9c>] ? saa716x_tbs_pci_probe+0x294/0x294 [saa716x_tbs_dvb]
[    6.903819] RIP  [<ffffffffa02dc029>] tbsfe_attach+0x3/0xfda [tbsfe]
Tried on Ubuntu and Debian - same result.
Any ideas what is causing this?
limiteddi
Re: Card not recognized
Postby limiteddi » Sat Apr 05, 2014 1:48 pm
Anyone?
limiteddi
Postby crazycat » Sun Apr 06, 2014 2:55 am
make menuconfig
And increase DVB_MAX_ADAPTERS to 16 (default is 8).
