Re: Installing QBOX Kubuntu 3.11.0-12-generic
Postby updatelee » Thu Oct 10, 2013 8:46 pm
Do you need the bttv module? Otherwise disable it
Postby updatelee » Fri Oct 11, 2013 2:03 am
did you disable the bttv module in make menuconfig ? as it seems to be causing a problem with the make process.
Postby updatelee » Fri Oct 11, 2013 3:12 am
Honestly never use the remote, I think the remote is usually handled by lirc if I rem right.
Ignore the led if it's wrong. The led doesn't effect signal quality
Postby updatelee » Fri Oct 11, 2013 4:59 am
Im not really interested in the whole home theatre style tv watching. Im actually more interested in the stream analysis. Windows had a few good applications, TSReader being one of them but there wasnt anything really for Linux. So I wrote my own, updateDVB
download
https://bitbucket.org/updatelee/updatedvb
screenshot
http://tinypic.com/r/2qjem1c/5
To get full functionality out of it you pretty much have to run my custom kernel modules that support additional functionality not supported by the stock linux kernel. I have quite a few stv0900/stv0903 devices supported plus some others like the genpix skywalker-1 (DVB-S, turbo-fec 8psk/qpsk, Digicipher II, DSS) and a few ATSC devices. You can use any DVB/ATSC device but you wont get the extra's like SNR in dB, spectrum scan, IQ plot, additional modulations, etc
