Issues with HD channels
Postby mpmc » Sun Jul 24, 2011 8:37 am
Hi all.
I'm having issues with the UK Freesat HD channels randomly glitching under kaffeine on Kubuntu 11.04 64bit, by glitching I mean audio pops & slow down of picture, when I pause & let it buffer it plays back fine no issues or anything, Is this a fault with the box or kaffeine?
I know I could just pause and let it timeshift for a few minutes but it's rather annoying having to pause it every time I change channel.
Other than that I'm extremely pleased with the device.
Any advice would be gratefully received :D
mpmc
Re: Issues with HD channels
Postby SergioDanielG » Mon Jul 25, 2011 9:38 pm
This is caused by:
* Small buffer size in Kaffeine (I don't remember how to change it)
* Poor quality or signal. Maybe adjusting your dish and lnb can help. Or with a more big dish.
SergioDanielG
Postby mpmc » Tue Jul 26, 2011 12:13 am
Thanks for your reply.
I'll look into the buffer problem, I've tested the box on three machines My Windows 7 64bit Intel i5 machine bluescreens when I try to scan for channels using TBSViewer or WMC. My Windows 7 64bit Nettop AMD Neo II works perfectly fine using TBSViewer & WMC when watching SD channels, I know it's too underpowered to do HD and finally my Kubuntu 11.04 64bit Intel C2D has the issues with Kaffeine on HD again SD perfectly fine.
Just done a quick google & found this regarding the buffering issue, I'll update if this fixes it.
Update:
Increasing the buffer size & turning off deinterlace fixed it, I guess even my C2D isn't fast enough :shock:
mpmc
