[Fixed] Latest Ubuntu Kernel dvb_usb_device_init (err -22)
Postby mpmc » Sun Nov 27, 2011 11:06 pm
I've just updated my microserver to the latest server kernel 3.0.0-13-server (64Bit), I've re-built the kernel drivers for my QBOXS2 which build no problem but the driver complains (when inserting the USB cable):-
[10090.487336] dvb_usb_tbsqboxs2: disagrees about version of symbol dvb_usb_device_init
[10090.487349] dvb_usb_tbsqboxs2: Unknown symbol dvb_usb_device_init (err -22)
Any help would be gratefully received! :D
Update:
It seems there was a conflict between driver versions, cleared out the modules, rebuilt and all is well =D
Thanks to TBS support for pointing this out :P
mpmc
Re: [Fixed] Latest Ubuntu Kernel dvb_usb_device_init (err -2
Postby Benvandamme » Tue Dec 13, 2011 3:26 pm
I have the same Problem. I made a new installation auf Arch Linux 3.1.4, compiling and installing, using "make all" and " make install" went fine but the module won't load.
I hav a Tbs Qbox 5910 I think.
root@ben-server ~]# dmesg | grep dvb
[ 3.357887] dvb_usb_tbsqbox: disagrees about version of symbol dvb_usb_device_init
[ 3.357905] dvb_usb_tbsqbox: Unknown symbol dvb_usb_device_init (err -22)
[root@ben-server ~]# lsusb
Bus 001 Device 002: ID 734c:5910 TBS Technologies China
Bus 003 Device 002: ID 05af:0319 Jing-Mold Enterprise Co., Ltd
[root@ben-server ~]# uname -a
Linux ben-server 3.1.4-1-ARCH #1 SMP PREEMPT Tue Nov 29 09:08:04 UTC 2011 i686 Intel(R) Atom(TM) CPU 330 @ 1.60GHz GenuineIntel GNU/Linux
Benvandamme
Postby Benvandamme » Tue Dec 13, 2011 6:29 pm
Also with the 2.6-lts kernel it is the same Problem.
[root@ben-server ~]# modprobe dvb_usb_tbsqbox
FATAL: Error inserting dvb_usb_tbsqbox (/lib/modules/2.6.32.49-1-lts/kernel/drivers/media/dvb/dvb-usb/dvb-usb-tbsqbox.ko): Unknown symbol in module, or unknown parameter (see dmesg)
Benvandamme
Postby Benvandamme » Tue Dec 13, 2011 7:22 pm
With the 2.6 Lts-Kernel and the sources from November the 15th it works.
Benvandamme
Postby Benvandamme » Tue Dec 13, 2011 7:45 pm
Will this be fixed in the future ?
Benvandamme
Postby cody » Tue Dec 13, 2011 8:30 pm
Benvandamme Wrote:Will this be fixed in the future ?
hmm, i think maybe there is nothing for fixing actually - it seems to me most likely there is some "leftover" in your kernel from the old 'dvb-usb' modules before install the TBS modules. so, have you tried with simply removing all DVB modules from your kernel:
# rm -rf /lib/modules/<kernel_version>/kernel/drivers/media/
which in your case i guess is something like:
rm -rf /lib/modules/3.0-ARCH/kernel/drivers/media/
and then re-install ('make install') the drivers as 'root' user.
Postby Benvandamme » Tue Dec 13, 2011 8:59 pm
That did not solve my problem. It stays the same.
When I do modprobe -f dvb-usb-tbsqbox the messages.log says:
Dec 13 14:01:39 ben-server kernel: [ 173.027656] dvb_usb_tbsqbox: module_layout: kernel tainted.
Dec 13 14:01:39 ben-server kernel: [ 173.028261] usbcore: registered new interface driver tbsqboxs1
Benvandamme
Postby cody » Tue Dec 13, 2011 9:23 pm
Benvandamme Wrote:Dec 13 14:01:39 ben-server kernel: [ 173.028261] usbcore: registered new interface driver tbsqboxs1
and what happens after the above message, because it seems it registers the interface and thus some error must happen after that in order to fail.
BTW, you use the following driver:
http://www.tbsdtv.com/download/common/l ... 111118.zip
right?
Postby Benvandamme » Tue Dec 13, 2011 9:32 pm
It is only loadable with --force and no device is created or so. It is totally unusable. Yes I used the latest driver.
I think when the device is registered the firmware should be loaded and so on.
Benvandamme
Postby Benvandamme » Tue Dec 13, 2011 10:12 pm
Any other Idea?
Benvandamme
