Help needed QBOXS2 wont work While TBS5922 does
Re: Help needed QBOXS2 wont work While TBS5922 does
Postby steven » Sun Oct 09, 2011 8:55 pm
1) please, provide full 'dmesg' log after lock attempt with your Qbox
S2 is performed:
# dmesg > log.txt
2) how you tested to get lock? which application you used? please, try
with 'szap-s2' and give us your 'szap-s2' configuration, command line
you used and details about the transponder you're testing.
and you have installed the driver twice so it should be ok ,the drivers are installed and loaded
correctly.
