TBS 8920 and ASUS motherboard
Postby FOXUIO » Fri Jul 26, 2013 3:41 am
TBS 8920 and ASUS motherboard automatically restarts.
The solution is to disable the BIOS ANTISURGE Support on Monitor Settings
Somehow trying to change channels mistakenly detected as a surge, but disabling this feature, the card works properly
Hope this helps anyone who has this problem.
ASUS MAINBOARD
P8H77-V
FOXUIO
Re: TBS 8920 and ASUS motherboard
Postby steven » Tue Jul 30, 2013 10:58 am
Hi FOXUIO
Thank you very much for sharing your method. :)
