[ Moderator Control Panel ]
by far » Fri Jan 13, 2012 10:56 pm
There seems to be a bug with the latest Unicable capable TBSViewer in that it doesn't recognise the Ctrl+P keyboard combination which means, even if the combination is learnt using the TBS Remote, one cannot use the Pause button on the remote.
far
by steven » Tue Feb 21, 2012 2:09 pm
Hi far
Next version we will contact DVBViewer solve this problem,Would you mind tring the older version first.
